Looking for someone with a little more experience to advise me regarding a current build. It's a basic 5F1 - repl. Fender trannies, tube recto, etc. Changes I've made are 1) beefed up supply caps: 40mfd/500v, 20mfd/500v, 20mfd/500v, 2) lower supply resistors for a little higher voltages 1K/1W, 10K/1W, 3) addition of 1N4007 diodes to recto inputs/outputs (ss bridge backup for 5Y3), 4) ability to switch in simple tone stack (5E2 tone control), 5) switchable RC cathode circuit at 1st gain stage (25mfd/1.5K, .68mfd/2.7K) 6) switchable NFB level which all should work with no problems I'm aware of other than 40mfd 1st supply cap is maximum a 5Y3 can handle. Regarding this I've 2 relatively simple questions. I know I can experiment & find this out on my own but... soooo... my questions...
1) since I'm using all new top quality components I no 2.7K resistors in my box & don't wanna wait 3 or 4 days on the UPS driver... Would it change things much if I substituted a 3.3K resistor or if it's thought better a 1K & 1.5K in series?
2) The stock NFB resistor value is 22K & I know omitting it increases gain but not always desireable so I was thinking of adding a switch that instead of eliminating entirely would drop a lower value. 2 ways I've considered doing this are switching in a 2nd 22K resistor essentially cutting the resistance value by half if I remember my training from electronics school so many moons ago or just switch the stock 22K out of the circuit switching in a lesser value... thinking 1/4 or 5.6K value. Can anybody suggest which would be the way to go??? Keeping in my I'm looking for a modest but noticeable increase in gain. Also is would there be any benefit to also adding a cap to ground HPF in the NFB loop? If so any suggestions as to what value might work well .01mfd, .1mfd, larger?
Any help would be much appreciated... pix of this build to follow shortly.
