Hi,
I am a lot confused about the specific position of the 100mdf-450v filter cap on the far left positioned backwards from the others.
Scenario n°1: In a stock SF Deluxe all the filter caps should be wired in parallel with two 10k resistors. , all caps are positioned with the positive polarity on the same side.
Scenario n°2: In bigger Fender amps , (from the left) we have two 100/350v caps wired in series and the first of those caps , exactly the one on the far left is always shown in layouts positioned backwards from the others , between those two bigger caps there are two 220K 1 watt bleeder resistors . The others, three 20mdf caps are wired in parallel with 1k & 4.7k resistors.
Actually in my amp I have five 20mdf-500w wired in parallel and all positioned on the same side/polarity with two 10k resistors.
"I will need bigger filtering in my SF Deluxe , in order to mod my amp for more clean headroom I just got two 100mdf-450w and three 20mfd-500w , new transformers for it ; super reverb/bassman PT and super /bassman OT with 8ohm tap ,SS rectifier and Legend 1218 150w speaker.
Then I was planning to switch to the second "scenario" with the two 100mdf-450 in series with 220k resistors and the other three 20mdf-500 in parallel with 10k resistors."
pls the question is:
1)in a SF Deluxe that is choosen the second "scenario" , in which polarity position should be soldered the first and second 100mdf-450 cap?
(considering that in my Deluxe wil be also installed super reverb/bassman PT and OT with 8ohm taps and SS rectifier)
2)Should I respect the same actual existing polarity position (actually all the filter caps are positioned with the positive polarity on the same side) even placing the two 100mdf-450 with 220k resistors ? or place one of those two caps in backward position from the other ?
(also in this case , considering the PT , OT swap and SS rectifier)
I would not do this work myself , a tech will do it for me but he does not know too much about Fender amps and asked for information about this specific filtering question.
In the area where I live, in Italy I coudnt find nobody that can help.
thank you in advance , John
