i have a pignose 40, I bought a 10k fender bias pot and was going to put it in series with the 56k resistor thats in the amp.. While I was at it I was going to add test points for biasing..
Question 1- Is the 10k pot going to be fine with the 56k resistor? or do i need a lower value?
Question2-Banana clips=2 power and 1 ground...
Is this right, the test points wire from pin 8 of each power tube to the(+)banana clips .. then from each (+) to the (-)banana clip with 1 ohm 1% resistors.. Then ground to chassis from (-) banana clip.. Correct??
i was also trying to get more bottom end and a little more clean sound out of the volume..
heres what i have done.
Ok, i swapped C17 for a .1uf cap, swapped C14 with a .047uf, removed C9 but put it back with an brown drop .047uf cap, and R11 to a 1.5K resistor.
this only gave me a little more low end on the distortion side..
I also had to re-arrange my pre-amp tubes from V1-TungSol 12ax7, V2-RCA 12av7, V3-Mullard 12ax7,
TO
V1-RCA 12av7, V2-Mullard 12ax7 and V3-TungSol 12ax7. Just to get it to sound ok with distortion/overdrive..
I have a TungSol 12at7 on the way but its been lost in the mail. so this is what i have for now.
TO
