I've got a Sunn Model T Reissue (Fender-made), and it has a very standard Fender tube FX loop in it. Everything works as it should in terms of gain, level control, whatever. It's relay-switched from either the footswitch or a switch on the back of the amp. It has separate send/return controls for each channel (helpful!).
Except: it seems like when the loop is switched in, the tone changes pretty significantly. It has a nice broad midrange with the loop out of circuit, then a very "scooped" sound with the loop in. More bass and more treble --- makes me want to stop playing and twiddle knobs. This is true regardless of what effects I use, whether they're bypassed, or even with just a patch cable between send and return jacks. It's also unaffected by what brand/type of tube I put in.
The loop works so well in terms of functionality, I just want to be able to switch effects in and out without the weirdness of a sudden dip in the midrange. Any ideas for how to deal with this?
Am I just being too picky -- is this normal for a series loop? All my other amps have solid-state parallel loops, so my expectations could just be unrealistic.
Preamp schematic attached. The FX loop is down at the bottom, V5A and V5B.
