Hello, I wonder if I can ask y'all some advice on an amp I'm trying to get fixed up for resale. It's a Univox U-1000 -- the schematic is here:
http://www.univox.org/pics/schematics/u1000.gif
... only what's inside the amp doesn't quite match. The B+ voltage is significantly higher than listed at all 5 reference points. The large 10u/2W resistors between the 6L6GC power tubes and ground have been replaced with 1000u/5w resistors, which appear to be of much newer vintage than all the other parts. I'm thinking the high voltage and the new, larger resistors might be related. At any rate, all of the tubes are running on higher plate voltage than listed, with one exception (see below).
The amp basically works, but for some reason the tremolo circuit is sending a putt-putt noise through the amp even when the tremolo footswitch is off. Also, the reverb section has tons of buzzzzzzz when turned up. The voltage on the plate of the reverb half of the 12ax7 is too low, only 90v -- my theory is that somehow the other half of that tube is running on such high voltage that it's causing current to cross between the two halves. Replacing that tube with a NOS reduced, but did not entirely eliminate, the problem.
I guess my first question is: is it possible for current to bleed across the two halves of a 12ax7 like that? And my second question is: did someone increase those resistors as a tone-adjustment mod? Is that a legit thing to do? It seems nuts to me, but i'm new at this.
I should add that I tested all the other resistors and caps, and found nothing severely wrong.
Thanks for any advice.
-mykle-
-mykle-
