How can I add harder clipping to this circuit?
  • How can I add harder clipping to this circuit?
    Hey guys,
    this is the same DAnelectro Honeytone guitar amp schematic that i posted in a previous thread. It has two 1N4148 diodes at the pre-amp stage and im guessing these are soft clipper diodes. I know it has an overdrive pot but I would like to know if:
    I can add harder clipping to this circuit? I was thinking add more diodes but im not sure in what way.
    Also i would like to add a switch so I can change from soft clipping, medium to hard? Any ideas how i could do this?
    Cheers guys!
    Originally posted by markbr View Post
    Hey guys,
    Cheers guys!
    I have one of these. I use it to tune backstage sometimes. Ugly little amp. The only thing I can suggest is to use germanium diodes. They will propogate around .3v rather than the .7 for silicone diodes (D1 and D2) and clip earlier. I guess you could add a switch to take them in or out. Just parallel them up with the others an use a dpdt switch.
      Forget diode swapping and just increase the gain of the preceding stage.
