Hi All I have a very old PYE Amplifier , Radio died years ago. Soo was planning if possible to convert the amp block to Mono Bridged and use it for a small Subwoofer.
I was told ages ago that it was possible, But as im still in the getting to grips on amps Stage as im a Lampie By Trade.
What i can Tell you about the amp is its a ( HIFI Sound Project 6691 )
The outputs are TIP42C and TIP41C.
Power Caps are 35v 4700uf
There is no markings on the transformer but there 2 supplies one (ac - ov -ac ) and a (ac - ac Which Powered the 12v Back-light Fuse bulbs)
After having a look at the PCB it looks as though the two amps are completely separate other than shared power and shared PCB. but the inputs and outputs are each to there own board.
Hope Somebody can help
p.s Also I want to make a Pre amp Board, With Volume Control and Low pass Active Crossover
Thanks Joe
Thanks Joe
