I like to have a sense of humor about things so I built this L-Pad attenuator in a coffee can, and it turned out great! I want to thank you guys that gave me advise and tips on getting this thing done.
It's a 100 watt L-pad but I wouldn't use it with an amp more than 30, maybe 40 watts or so. I ran my Bandmaster into in during the testing stages and it got pretty warm, but that was before I installed it in the can with the fan and attached a heatsink to the L-Pad. It works fine with the Kay and only gets mildly warm even dialed way down with the amp dimed. The Kay is about a 20-25 watt amp. It would work fine with a Princeton, maybe a Deluxe Reverb, certainly things like Champs and Valve Juniors.
The switches:
Expresso/Decaff = Bright switch
Light/Strong = Bypass
Jacks:
Amp in
8 ohm speaker out
9-12v dc for fan
The bypass is a good idea because there is still some attenuation even with the L-pad up all the way.
I won't get into details but preparing the can and the label was a B*itch!!!
The electrical part took only a few minutes to wire up. I had most of the parts but if I had to buy it all again it would cost about $35, not including a can of coffee.
It certainly sounds just as good, and maybe better, (maybe because I made it myself ) than my Sholtz Power Soaks.
The switches:
Jacks:
Amp in
8 ohm speaker out
9-12v dc for fan
