It really annoys me that there is no mute switch on this amp. It's the only thing that spoils a great amp. So is there anyone here that can help me with modifying my amp?
What I want is the mute to kill the signal to the speakers AND the DI output, but leaving the signal to the effects send intact so I can tune silently and without sending the signal to front of house. If it helps, I always use the DI output in post-EQ mode. Looking at the circuit diagram, it seems the pre-EQ mode takes the signal before the effects send. I'd go as far as to say that the pre-EQ switch is pointless since I can do the same thing by linking to the amp input from my bass plugged directly into a DI box so I might even hardwire the DI to post-EQ and perhaps use the switch for a mute.
I am competent with a soldering iron and fitting switches to the front panel, I just need to know where to break into the circuit and what sort of switch I'm likely to need.
I'm using this diagram
Thanks in advance
Thanks in advance
