Hello
I am in the planning stages for doing some of the common capacitor mods to my PV Rockmaster preamp. While I expect that to go without a hitch, I have a couple of Q's about further mods I cannot find info on - plus I'm not too good at reading schematics yet.
I've read about cathode followers a bit, apparently adds some 2nd order harmonics that the high gain modern amps lack - like many Peavey products. Is it possible to add a cathode follower to this preamp? Is it simply about adding a resistor somewhere or does it involve some serious plumbing? I should also clarify that I'd like to do this by converting half a 12ax7 stage instead of adding an additional tube. Unless adding a tube is less complicated.
Looking at the schematics (attached to the thread) for the RM and my power amp (Peavey Classic Series 60), it appears both have a SS rectifier. Am I seeing this correct? I've seen tube rectifier conversion kits available, which one should I replace to get some sag? Can I do both?
There also is an active eq on the crunch and ultra channels, is there a way to bypass this entirely? I'd rather use a passive rack eq for tone shaping, and I suspect an active eq won't do well with a cathode follower.
Rockmaster Schematic
Download peavey_rockmaster_preamp.pdf from Sendspace.com - send big files the easy way
Classic Series 60 Schematic
Download Classic 60 schematic.pdf from Sendspace.com - send big files the easy way
Thanks for your support!
