I have a Bugera 6262 that I use to test my ideas on. The amp is a Peavey 5150 II copy. The amp actually has pretty decent tone. Being 100 watts is a bit excessive for me. I pulled two tubes and still too much volume to hit sweet spot. I had a couple of 6v6's around plugged them in for a minute or so. They amp seemed to be ok. Bugera will not release any schematics so no help there. The amp has a bias test point. What do it need to do to ensure that I don't fry anything?
How to safely run 6v6 tubes in place on 6l6's?
Those voltages are to high for 6V6's if they are over 380 volts which the 5150 runs at about 500 volts on the plates. You will eventually fry them and burn them up quickly causing possible damage if the fuse doesn't blow and the tube shorts from grid to Cathode or other shorts.KB
the JJ 6V6s will do 450v on the plates - if the Bugera is around the 450v mark, you'll probably be alright.
(5 mins later)... ok, a google search reveals this page... Properly Biasing Bugera Amps - BeerChurch's Blogs | Ultimate-Guitar.Com It states that the Bugera 6262 has a plate voltage of 480v - probably a little too high for hard gigging, but they'll probably be ok for home use.
you could always cut the B+ down by 50v with some zener diodes between the PT's CT and ground. with around 400v B+ you'll be fine to run JJ 6V6s.HTH - Heavier Than Hell
Originally posted by HTH View Postthe JJ 6V6s will do 450v on the plates - if the Bugera is around the 450v mark, you'll probably be alright.
There may be impedance matching issues though. In my Rivera I run them in place of EL34's but rum a 16 ohm speaker with a 8 ohm amp output to match. Not sure what pulling two 6L6's then using two 6V6's will need.BobLast edited by rockon1; 04-12-2010, 01:31 AM."Reality is an illusion albeit a very persistant one " Albert Einstein
doesn't running a "not a true" 6v6 that takes higher plate volts and dissapates more watts sort of defeat the postes intent of power reduction?
I agree with dropping the B+ if you want to use 6v6's. But keep in mind that a pair of 6v6's will need a significantly higher OT primary impedance than a quad of big bottles so you'll need to make adjustments at the impedance switch or speaker load (or maybe both) to get a pair of 6v6's into their ideal load in that amp.
Or you could just use four 6l6's and invest in a good attenuator.
Chuck"Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View Postdoesn't running a "not a true" 6v6 that takes higher plate volts and dissapates more watts sort of defeat the postes intent of power reduction?
Chuck"Reality is an illusion albeit a very persistant one " Albert Einstein
Originally posted by Bob M. View PostWhat did Jim Kelley know that is not being illuminated here?
- Scott
