Reverb Switch question
  • Reverb Switch question
    Hello,
    I am trying to build a reverb switch for two different amps both with their own independent switch for on / off.
    I know its simple to do, but I am having some trouble with the LEDs and switch pairing.
    What would be better to use a DPDT or a 3PDT?
    Im basically going for two inputs to the amps as well via 1/4". Do I need to use TRS or mono is I am using a LED?
    My power supply is a 9v battery.
    Any suggestions on wiring this?
    I have a 2.1v LED paired with a 390 ohm resistor. That is correct right?
    Thanks to anyone that can help me with this!!
