Originally posted by imaradiostar
View Post
Blackfacing a 135W ultralinear Twin Reverb?
Yup... But a nod to LG on the idea of a simple series resistor. BUT... Make it a Pi filter! Decouple, then a resistor, then decouple again. The resulting circuit, with a hanging cap to ground, a resistor and then another hanging cap sort of looks like the Pi symbol. That's how it got it's name. But it's remarkably effective at reducing voltage and sag at the same time. I'm sure there is some math to determine exact benefits. But the dual caps reload faster than the time constant of the circuit, basically. So you get a voltage drop, a reduction in ripple AND acceptable sag in many cases."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostYup... But a nod to LG on the idea of a simple series resistor. BUT... Make it a Pi filter! Decouple, then a resistor, then decouple again. The resulting circuit, with a hanging cap to ground, a resistor and then another hanging cap sort of looks like the Pi symbol. That's how it got it's name. But it's remarkably effective at reducing voltage and sag at the same time. I'm sure there is some math to determine exact benefits. But the dual caps reload faster than the time constant of the circuit, basically. So you get a voltage drop, a reduction in ripple AND acceptable sag in many cases.
OK now back to the 135W Fender, already in progress.This isn't the future I signed up for.
blackfacing everything on it besides the ultralinear sounds awesome
Also, when working properly (i.e. crappy old electrolytics replaced, adjustable bias added and set correctly, messy lead dress cleaned up) those amps sound REALLY GOOD already, in spite of all the internet nonsense you read to the contrary by people who've never played through one or at least one that was in proper working order. Yes, they stay cleaner longer. Are you pushing a blackface twin into breakup? Really? I don't know any club that wouldn't get you removed from. If you need that kind of volume nowadays, you are mic'd and through a PA. Most people use a clean amp and pedals. They are excellent amps for that, along with Pedal Steel, Keyboards, etc.
Like Bob p write.
Ultralinear Fenders are King of Clean.Keep it that way.
I just do not understand, why should for example mod Marshall amp to get Fender? Buy what you like.
It is cheaper to buy BF Fender then convert it. My UL SF Pro reverb is fine, but is lack for more warm tone. And this can be easy to correct and not expensive.
