Speaker mounting gasket material
  • Speaker mounting gasket material
    Hi guys,
    Didn't know where else to post this q...
    I've got an EV 12 speaker I want to front-mount in a new cab. The speaker comes with gasket material on the front edge (for back mounting), but none for front mounting.
    What should I use?
    Thanks much!
    Is this one of the reissues? I front-mounted mine, and there was no gasket on the back as you say, but I just stuck it in without one. I guess you could use foam weatherstripping, which you can get from home improvement stores like Home Depot, B&Q etc.
      Yep, one of the re-issues... I think you're supposed to make that an airtight seal if possible. I guess if nobody has any other ideas, I'll just use some foam weatherstripping.
        Go to an auto parts store and get a sheet of gasket paper. You can also use plain old cardboard (not the thick kind with air spaces in it) or even the large thick sheets of poster paper for $1 at Walmart.
          I use thin (1 mm) spongy EVA rubber, the kind used for mousepads and toddler room decoration.
