Greetings all,
I recently posted this over at the gear page, but there doesn't appear to be much action over there...
I've got a fender super twin reverb (Amp Guide » Fender Super Twin Reverb) I picked up a few months back. I know these aren't the most highly thought of amps in the twin family, but I really like it's clean sound.
I've been modding the amp a bit, moved the input to the reverb to the rail above the 5-band eq, that added a lot of warmness to the reverb. I've also picked up the gain a little in the pre-amp, and disabled the "distortion" triode in the 6C10 - will probably use that triode as a gain stage at some point. Also replaced the electrolytics in the entire amp, PS included.
It's a really loud amp; 180w of ultra-linear fender clean. I wanted to experiment a bit by removing the ultra-linear mode, either going with pentode or triode mode.
I put in a heavy duty DP/DT switch and wired it up.
Triode mode: no problem getting the power from the plates (which is run to the screens through the existing 470ohm resistors (2w btw - I replaced them when I bought the amp).
Pentode mode, I'm current getting the screen power direct from the B+ node that feeds the OT and then sending it through the existing 470ohm screen resistors. In other amps I've seen with pentode mode, there is usually a resistor (or a choke) and another filter cap (node) on the B+ to feed the screens.
Since the screens were previously being fed ultra-linear, they were getting the same voltage as the OT B+ tap (which is 500v, btw - yikes), and are getting that via triode mode as well.
My question is this; in pentode mode, is an additional node in the B+ necessary to feed the screens?
I will say this; there is a nice drop in volume in triode mode, however the amp sounds a little better in pentode mode. AND pentode mode sounds WAY better then it did in ultra-linear - not going back to that. Pentode mode is a bit quieter then ultra-linear.
Maybe some pics would help...
Omitting the switch, here is pentode mode without a node off the Center tap of the OT (B+) would look like:
And here is pentode mode with a node, dropping off some voltage from the B+ to the screen:
And triode mode:
And ultralinear (for completeness, taps are now taped off on my amp):
The question: is the first method ok? I've not seen a stock amp like that, that's why I ask. It seems to me that if it was ok to run ultralinear, and it's ok to run as a triode, that this should be fine as well.
Thanks for any help.
And triode mode:
