Hi,
Please can anyone could describe how to make the conversion
of 2x6L6 to 2x6550 power tubes on a 45/50w Fender amp?
I need to switch to 6550 in order to set for a cleaner sound with
very, very late break up (or no break up at all) , for Jazz use.
I read that is raccomended to hook up the pre amp tubes to an aux 6,3V
3 amp auxliary filament transformer;
Since my Super Reverb PT is 220/230/240vac model ; which Filament
Tranformer would fit for the application? Any model/or brand to suggest pls ?
On circuit board I have 220K bias-feed resistors to which values
those need to be changed for 2x6550 ?
Should I also change the 470R screen resistors to 1K 5W ?
Below there is a description of the amp and of all the mods
that I already done . Everything has been done very neat and clean;
Fender SF Deluxe Reverb circuit ; I replaced all electrolytic caps
(cathode,bias,filter caps) with brand new ones , the phase inverter section has been converted exactly to SF TR specs
Filter Caps: 2x 220uF-350w and three 20uF-500
Tad Super Reverb PT this tranformer have the option of more windings taps for solid
state recto) I'm using the recto taps hooked to a TR style
Rectifier board w/6 5408 diodes
MM SuperSix Reverb OT 2/4ohm taps: hooked w/ 2ohm tap
2x10 8ohm-100w Delta Demon Emi's speakers
TR style Choke filter
Power Tubes: 2x6L6 SED winged C
Pre-Amp Tubes: EH12AY7 in V1 , Fender12AX7 in V2, EH12AT7 in PI
This amp actually sounds beautiful but starts to break up on 6 on the dial
and I wish to get a very clean sound from it (similar to a TR or a bass amp).
thank you , John
thank you , John
