The only tube amp I have right now is my Pignose G40V. I've never had trouble with it and I really like it (with 12AT7 in V1 and speaker change), but I know it's cheaply made and I have to be careful that it doesn't overheat. I guess I got lucky because I haven't had much problem with it (had it for 6 years).
Anyway, the question is, will removing the negative feedback loop make the amp run hotter, as in temperature?
Here is a link to the schematic - http://www.blueguitar.org/new/schem/...gnose_g40v.gif
I am going to replace the filter caps and improving the grounding and want to see what it sounds like without a negative feedback loop. I will probably also install a fan.
Any help will be sincerely appreciated. Thanks!
