First a big thanks, I have learned much reading through this forum.
I typically see individual screen grid resistors attached directly to the sockets. This amp uses one 2k-5w resistor at the B+2 filter cap then runs to both tubes. Is this a noise issue? Should I run B+2 to individual 2K's attached directly to each socket?
Secondly should the rectifier diodes be updated for noise or safety reasons?
I see the 2k-5w resistor is only 1/2w I assume from the factory. I'll replace that lightly browned resistor for sure.
EDIT: typo fixed
EDIT: typo fixed
