Mesa DC-3 bias too hot
    Heres a picture of the 2M2 resistors (I believe) as one side goes to pin two. Bob
    "Reality is an illusion albeit a very persistant one " Albert Einstein
      Lift one end and connect in series another 2M2 resistor. The negative voltage rises with it.
      After, fine-tuning is required. Depending on the degree of the tubes may need to raise the final value.
        Or assemble the tested and working circuit I posted above on a small PCB and you'll have real bias adjustment.
          Well I decided to bump down the 120k . Got 13.7 on pin 2 now. The PI bias barely moved. If I was to do it nicely I'd put a 76k and 50 k pot in place of the 120k and perhaps a 20k pot in place of the 15k Pi bias resistor. Bob
          casinolevant levant casino
