Putting together a 5E3 with 6L6's (see schem) and the PT I have does not have a bias tap. Whats the best way to drop the HV 380v winding (380-0-380 PT) down to 50v for the bias circuit?
PT without bias tap
I know there are ways for taking bias from the HT, but I much prefer taking a small heater transformer and run it backwards off the heater supply. Meaning, take the 6.3v side of the transformer and connect it in parallel with the heaters and take the 120v primary and use it for the bias. You'll need to tweak the values of the resistors in the bias supply to give you the proper voltages, but this way works great.-Mike
You could do it the old Ampeg way. I would use a 25K pot and a 51K resistor in series instead of the 68K resistor, so you can adjust the bias.
http://www.drtube.com/schematics/ampeg/gv22-jp.gif
Originally posted by defaced View PostI know there are ways for taking bias from the HT, but I much prefer taking a small heater transformer and run it backwards off the heater supply. Meaning, take the 6.3v side of the transformer and connect it in parallel with the heaters and take the 120v primary and use it for the bias. You'll need to tweak the values of the resistors in the bias supply to give you the proper voltages, but this way works great.
how about taking ac off of the HT leads with a pair of 100K 1 -2 W resistors feeding the bias circuit on the schematic? you should use a diode after the 100k resistors and tie them together instead of a single diode. kind of like the Ampeg cap divider but using resistors....
Originally posted by Diablo View PostI understand you want to source 120 VAC for the bias, but why would you need a transformer to do this? Couldn't you just use 120VAC coming in from the power outlet and the fuse? What is the benefit of going through two transformers to get the same voltage you started with?
The Darwin Awards
Originally posted by Albert Kreuzer View PostYou don't want to connect your guitar directly to the power outlet, do you?
The Darwin Awards
I second the "borrowed" bias supply as well. If there's a CT on the HT winding it's perfectly OK to do (most 50 watt Marshalls do this exact same thing).
Although I think 380-0-380 is a bit high, I think the 5Y3 rec valve is perfect for it. However, I would never run SS rectifiers on that voltage.Jon Wilder
Wilder Amplification
Originally posted by m-fineI don't know about you, but I find it a LOT easier to change a capacitor than to actually learn how to play wellOriginally posted by JoeMI doubt if any of my favorite players even own a soldering iron.
Originally posted by Chuck H View PostWhy not keep it simple. The 5E3 has a CT HV wind so there's no need to cap couple the circuit. This has been done without issue many times.-Mike
