I've got a Fender made "Model T" from the 90s. I know it's not the same amp as the real 70s Model T. My research leads me to believe that its preamp was an evolutionary stage in between the red-knob "The Twin" and the current "Twin Amp", with some extra cathode-followers thrown in. I like it a lot.
The power stage of this amp is part-for-part exactly the same as the red-knob "The Twin". Same PI, same 6L6 output stage with 470R screen resistors and 1.5k grid stoppers. The PT is different so the voltages could be different --- this amp puts 480-490V on the plates and feeds the screens from a 3H, 90-ohm choke. The OT is the same part number as the red knob twin - 026478.
My problem is that I like to play really really loud, and the amp seems like it's breaking up too early. Not so early that there's clearly something wrong with it, just too early for something that's supposed to do 120W. I'm wondering where the bottleneck is. This is not a speaker efficiency issue, I have a 4x12 with 102dB Eminence speakers in it. Power stage is biased cold - 52% idle dissipation. When it breaks up the tone gets darker and loses bass and it's like the amp just rolls over.
Right now I'm thinking it could be the OT. I can't find specs on the 026478 OT, but Hammond just came out with a drop-in replacement (the 1750D) which says it has a "2350-ohm C.T. primary" (as compared with the usual 2000 for the Twin Reverb 100-watters). It does seem on the small side, compared with other 100W amps I have around.
I have a Marshall TSL that I had a similar problem with, and put in the Mercury upgrade OT, a choke, and put in E34L tubes instead of EL34s, because they're supposed to have higher headroom. One or more of those changes made that amp able to go significantly louder before it got "raspy". Interestingly, I emailed Mercury and asked about their red-knob twin upgrade OT for my Model T, and they told me to get the Mercury OT made for the 70s Model T! I suppose an OT that works with 6550s would work with 6L6s, but I don't need ultralinear taps or a 2-ohm secondary tap.
Any opinions on where the bottleneck is, and how I can address it? If it is likely the OT, what are my options? Can I actually put a MM 70s Model T OT in this amp if wanted to (aside from mounting considerations)?
schematics:
http://local.anchorstates.net/images...reissue-p2.jpg
http://local.anchorstates.net/images...reissue-p1.jpg
EDIT: If the OT really is 2350-ohm, I did a load line on the 6L6 curves and it looks like the arrangement will only do about 85W. Not sure if I did it correctly, but that's definitely not the quoted 120W.
schematics:
