So I have this champ amp:
http://www.thevintagesound.com/ffg/s...a764_schem.gif
I have a few things I wanna do to it. . .
First I wanna give it variable bias, I have a 250 ohm 5 watt resistor that will go in series with 500 ohm potentiometer
I'm not sure what I wanna do next but I do know that I want to bring up the gain just a bit, it's just shy of what I'd like out of it. So I was looking at this calculator I found:
Cathode Bypass Capacitor Calculator
tube type is 12AX7, cathode bypass cap is 25uf (im looking at the 12AX7 half thats right after the input), grid resistor is 33k (34k if the guitar is at input 1, but 34k wasn't an option), plate resistor is 100k, cathode resistor is 1.5k
So with those settings it says i have a gain of 29dB at 82Hz, and 29dB at 10kHz.
Any larger capacitor value doesn't do much for the gain, smaller values bring it down, I don't know very much about it so I guess I could expect that.
Now here's what is confusing me. . .
I set the plate resistor to a lower value, say 68k just for the hell of it, the gain is now at 28.3dB. Whatever resistor value I decrease the gain decreases as well, and whatever resistor I increse the gain increases. I expected the opposite, but what do I know? the best explanation I can come up with is that the smaller resistances create a smaller voltage drop and therefor less gain?
The last thing that really got me was changing the tube type. I just wanted to see what would happen there. With the settings set as I described above i had the 29dB gain, I change the tube type from 12AX7 to 12AT7 and the gain jumps up to 32dB. I always thought the 12AT7 was a low gain tube. . .
Any explanations for all of this? Thank you!
And any suggestions to bring up the gain just a little bit in the amp would also be appreciated!
