Hi All,
My first thread was about this amp, and did a few mods and like it a lot now. One last thing should be simple but is kicking my head... How can I lower the gain of the ultra channel to clean it up for no distortion? Its active EQ is great. I like to use this channel underdriven and clean with the Pre down low, and the Post and Master past 6 but its still a tiny bit dirty even in that configuration, not to mention how jumpy the pre-pot is.
I have tried putting 500meg or less across the 1M pre pot, but that just limits the upper end of the pot. Need to soften the entire pot range (thinking of chaning R8), or reduce the gain of these stages somewhere at the tubes.
Will changing the cathode bypass resistor value mess up tube bias?
I have colored the schematic as Blue=Tube Inputs and Yellow=Tube Output
