Greetings All,
There's been a fair bit of discussion here on MEF and elsewhere over the years about taming the power output/volume on a 5E3 by swapping-out the stock (12w) 6V6's for NOS 6K6's (8-10w), and I'd REALLY like to make this change to a '57 Deluxe Reissue equipped with 5Y3 rectifier, if possible, but its not particularly clear to me whether I can safely do so without making other modifications to the amp. In particular, its not clear to me what the plate voltage (B+) is likely to be on this Deluxe Reissue (with 5Y3) or whether I may need to change the PT or other components to reduce that voltage below the maximum specified for a 6K6GT (i.e., <315V).
Can anyone provide me with some sound guidance on this topic? Are 6K6's directly swappable with 6V6's in such an amp (plug-n-play), without the need for other mods? Or is the plate voltage likely to be too high (>315V), even with NOS 5Y3 rectifier installed? If so, is a complete replacement tranny the only approach?
Many thanks!
Many thanks!
