Hello! I have a vox nigh train 15, and have found this fizz as note decay when you play with the gain set at the point of breakup, (letīs say between 11 oīclock and 1 oīclock in bright mode) itīs not there when you play clean and when overdriven it becames a part of the sound so itīs not that noticeable. Many people have reported this problem on various forums all over the internet, but I canīt find a solution to it, I think one guy said it went away with a good retube but many others have tried that and the problem was still there. This is a sound clip of the issue, taken from another forum
MP3 Player SoundClick
As another guy said it sounds "like a dying transitor radio". Itīs really noticeable when you put down the master volume, and tends to desappear with the master set louder, but still there.
I have noted that the cathodyne PI in this amp is exactly the same as the 5E3, reading the Valve Wizzard site about cathodyne PIīs he states that the problem with this type of PI are not having a grid stopper, and power tubes should have bigger (100K ohms) grid stoppers. Does it has something to do with it or should I be looking for something else?
Thanks!
Silvio
Thanks!
Silvio
