Can you show us a diagram or schem of what you did?
IIRC the cathode voltage will rise to the onset of clipping and though it continues to rise the amp will be in cutoff at the clipping voltage. So the zener voltage needs to be higher than that. Without a scope you'll just need to get a couple of zener values to try. If you have 12V now then maybe 15V and 17V.
Also, FWIW, in my home experiments the added cathode zener offered a hair more improvement when used with the PR mod. And it makes choosing the PR mod zeners easy since they would be one or two volts higher than the cathode zener voltage. For example, you could use a 13V cathode zener and 14V PR zeners and the amp is certain to be in cutoff when the PR mod zeners conduct.
EDIT: It should be like this:
