I just finished refurbishing a ~1953 Multivox Premier 120 for a customer. This is the version in the overbite cabinet that uses 12AX7s, not 6SL7s.
I decided to do a little experimenting with it before sewing it up, so I tried clipping in a couple of output stage bypass cap values. The 300 Ohm shared cathode resistor for the two 6V6s is unbypassed with the amp in stock form.
What I found I liked was a bypass of just 1uF. It gives the amp a little chime in the highs without the excess bass of a larger cap. I suspect that the output of this amp is purposefully limited by negative feedback from the shared cathode resistor (as the output stage goes into AB1) in part to prevent speaker damage. The musical effect is compression at all frequencies.
I think I may have to let the amp's owner hear it to decide whether he likes the amp dead stock or with a bit of extra transient response in the highs.
It's amazing how much different cathode bypass values can change the character of an amplifier.
