CAN an AC30 be modified to USE THE TB CHANNEL AS AN EXTRA GAIN STAGE?...IOW CAN THE AMP CURCUIT BE altered to just have 1 (ONE) CHANNEL?...I Understand that the CUT CONTROL can be parralelled with a cap (RESISTOR)?... to make IT a MASTER VOLUME CONTROL...ANY IDEAS?
Ac 30 modification question
Originally posted by barnoyle View PostCAN an AC30 be modified to USE THE TB CHANNEL AS AN EXTRA GAIN STAGE?...IOW CAN THE AMP CURCUIT BE altered to just have 1 (ONE) CHANNEL?...I Understand that the CUT CONTROL can be parralelled with a cap (RESISTOR)?... to make IT a MASTER VOLUME CONTROL...ANY IDEAS?
1. Think about getting a different amp
2. Use a clean boost pedal
3. See #1
Interesting idea. IF I were to attempt it, I'd try something like this.
I built a Double C amp a while back that sounded good to me. Maybe you could adapt the OD to the Vox AC30 idea.
Double C amp - Hoffman Ampifiers Guitar Tube amp forum
I presume this is NOT a vintage amp? IF it is, leave it original.
With respect, Tubenit
OH no...this is one of the 1st amps I built back when Doug Hoffman started his web site long ago (geez aging sucks don't it/)...anyway ...no trem.../ reverb...I got nice new "bundle" IRON from TRIODE / CHAD...GREAT TONE!...SO...skies the limit I guess...frank.
Wow! Those poor cathode biased EL84s must get the crap beat out of them with all that gain!
And one could simply add a PPIMV after the LTPI (if needed) and before the power amp and get reasonable and controllable gain, IMO. So then you'd have a trim, level and PPIMV to protect the poor EL84 tubes.
