I've done all of the mod except one step, listed here: http://www.blueguitar.org/new/schem/...s/c30twdbm.pdf
"12. Cut the trace to pin 2 of relay K1. This is very important. If you omit this step or do it wrong, you will short the B+ on V2A directly to ground. This is a very bad thing."
I have no clue which leg of K1 is pin 2. Can someone tell/show me on the layout below?
Thanks.
Thanks.
