AC30CC2 Reverb mod question....
  • AC30CC2 Reverb mod question....
    Hello everybody! I recently did the reverb mod on my CC2, new accutronics tank, 28k metal film 1/2 watt resistor @ r18, 1M across lugs 1 and 3 of high low switch. After all that, the reverb is still incredibly faint. I've looked all over the internet and the only thing I've found is a guy who brought his amp to his tech after having the same problem I am having, and the receipt said the tech grounded the input of the tank. So, I went ahead and clipped a wire from the ground lug on the input jack of the tank and attached it to the tank case. It improved the reverb level, but it was a little distorted and there was significant buzz. What am I doing wrong? The tank is 9EB2C1B.
    I think if you post the schematic, it may help solve the problem, but you can start by un-modifying it.
    the mod did not solve anything...
    You can probably beg the sales rep for a clear schematic.
    And so, the original problem was that the reverb is too faint?
    And this is a built in factory problem?
