Hello people,
i´me building the Champ 5C1 schematic. Its my fifth DIY-amp project and I really love it. Everything works and sound above expectations except that one f**** problem every single ended amp builder gets to struggle with. Yes it is.... HUM... I want to get rid of it as much as it is possible.
What I did so far:
1. Connecting the CT from the heater windings (6,3V)
2. Making stargrounds according the article of R.G. Keen
These actions did make the amps a lot more silent
What I want to do:
3. Installing a brute force filter with a choke
I have found a schematic and a lot of information about the 5F1 Champ schematic. I want to build it in by a 5C1 schematic.
This is what I want to build:
According my studie of information on this and other forums it has to work but i´me not shure of it. Can you please check the values of the components and give me some feedback...
I was also thinking to separate the B+ line from the 6V6 and the 6SJ7. Than you would get something like this:
The reason I want to separate those B+ connections is because my logical brain tells me that it would reduce signal contamination from each other. However, this reasoning is not based on a good knowledge of electronics
It would be nice if someone with the right experience and knowledge could help me out with the right schematic and with the right values of the components.
Regards, ScarTube.
(Sorry for my bad englisch, I blame google translate :-) )
What I did so far:
What I want to do:
Regards, ScarTube.
