I have a Model One that has lost any hope of originality long ago (for starters the particle board cabinet literally disintegrated on a cross-country move).
I now have just the chassis and associated electronics, which have been the victim of many an experiment over the years. I've configured a base to hold it upright and so the tubes are protected, exposing the electronics to my deviousness.
Okay, enough with the prelims.
I've added a piece of metal to my wooden base to hold the speaker output jack, a master volume and preamp out jack. I often use the Kalamazoo as a booster preamp for larger amps. The master volume and preamp out jack are essential for this, of course.
In order to use the amp this way though it is necessary to remove the power tube (unless I want to use it to power a speaker, which I don't). I would like to add a switch of some sort to make removal of the tube unnecessary. Possibly it could even be part of a switching jack arrangement in conjunction with the preamp out jack.
What would be the best way to disable the power tube without having to remove it? Obviously, I don't want to blow the OT. Can I switch off the heater/filaments, for example? How would I go about that? I'm a bit clueless with this one (Hey, what else is new?).![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
I'll be offline till Thursday, but will return. Thanks in advance for any help.
