I just started in on doing the Moyer mods to a 2000 Fender Vibrolux Revereb. In the segment on adding a negative feedback loop, he mentions adding a 470 ohm resistor to the circuit and states that it is R42 on the circuit board of his '95 Vibroverb reissue, and that resistors place on the circuit board is filled with a jumper wire. That also describes the board in my Vibrolux; same jumper wire in place of the same designated resistor.
So what I'm wondering is: can the 470 ohm resistor be installed in that location and do what it's supposed to do in the NFB loop mod? In his description of adding the resistor, he says it goes between the point where the wire from the tip of the speaker jack goes to the circuit board and ground. When I do a continuity check between the jumper in R42's location and ground, I get continuity. But when I check between the newly installed wire and the R42 jumper, I get nothing. Seems like if that's where the 470 ohm resistor goes, and it's supposed to be between the wire connection point on the circuit board and ground, I should read a dead short between the jumper and the wire through the board, right?
Has anyone out there done these mods, and is my thinking right on this point?
Thanks in advance, group!
