I recently stumbled upon a change in my homebrew that made me realize i may have had the gain at the various stages less than optimal for the sound i'm going for. Thats not to say it didn't sound good before, but i changed something and the tone changed in a few ways, some good some not so good. Like a trade off, but i felt the trade off was a worthy one. I lowered the gain at V1B with a split load plate and raised it at a point after that. The change that i liked was a pretty considerable gain in playing dynamics and a wider tone that seems to have more highs but in a good way. The trad off was the low end isn't quite as tight.
Anyways, it caused me to start thinking about where the gain should take place in a 3 stage + cathode follower preamp. What do you think.....lower gain in the first stage and building later, or cleaner at the earlier stage and gradually building later on? When i say building later i'm not talking about gain getting higher as it goes because of course it does, thats what a cascaded pre is for. I mean designing later stages for more gain than earlier. Is that a good idea? Seems like it. I'm now wondering if i should ad that gain back to V1B and instead cut gain at V1A. By the way, a while back i did another thing that also seems to point to later stages having higher gain being better, and this seems unorthodox compared to all the marshall style MV amp schematics i've seen. I increased the typically 100k plate and 820R cathode of the stage immediately before the CF to 220k/1.5k and it has a 4.7uf cathode bypass cap. Seriously improved the tone. I tried to go back to the common values a few times and each time it was a jaw dropper how much fuller and better it souds with the higher gain there.
So In short, is there a way that is considered more correct when it comes to which stages should be gainier in a cascaded preamp, early or later? I just posted this to see what you guys think on the subject.
