Yup. Sound pretty much the same. Bit more top end chime, if anything.
The pentode usually has very slightly lower gain than a 7199, given the same B+ and resistance values, and the triode has roughly the gain of a 12AV7 versus ~12AU7/12AY7 for the 7199's (depends on the type how high mu the triode is).
In our experience, the triode is slightly better at rounding the rough edges off the signal, if used as a cathode follower after a gain stage, than the one in a 7199. But that's generally an improvement in tone, rather than a bad thing.
And they're cheap and easy to get, so...
