Back in 2007 i modified my Marshall JCM800 4210 Channel Switcher 50 watt combo and have been happy with it though new it could be refined.
Recently I changed the main power filter caps with new German F&T capacitors and got keen about working on the amp again.
Here is the original thread i started back then Marshall JCM800 4210 Channel Switcher
I've attached the original Marshall schematic, a modified schematic with the changes made in 2007 and preamp schematic of the proposed changes that I'd think could work well for the amp.
Essentially the clean channel has been left alone for now, all the work is the signal flow through the gain channel and removal of the clipping diodes. The main difference between the 2007 mods and what I'd like to do now is that the gain channel now feeds off the first triode in the clean channel and that the signals mix later on than before. Also the order of the FX loop and reverb is changed and the reverb mix is a virtual earth mixer.
Ive used Merlin's designing preamps book in the section about different amp designs for inspiration for the values of the inter stage resistors, capacitors and the cathode caps and resistors.
Please if you'd like to make some comments regarding the proposed changes that would be useful. Ive taken a bit of time considering things rather than jumping straight in with the soldering iron.
The next step will be to consider how it will all work on the PCB and whether the design idea will work with the physical layout of the amplifier.
edit: I've added another modification to the virtual earth idea, perhaps the fxs loop is better after the reverb, or maybe even return the reverb to other side of the PI
Happy New Year
Walkman
Happy New Year
Walkman
