Been running a pair in a marshall style amp with a 3.6k primary and 440 plate V with secondary set to 4 ohms with a 8 ohm speaker. I biased them to around 17Ma. I've always heard JJ's can take quite a bit of plate V and bias current. Any thoughts about this setup either concerning the bias voltage or anything else? I like el34's, but these things really help warm things up at low volumes so i'd like to have some peace of mind that this is a safe setup when i use it.
6V6 bias question
I know that the older JJ 6v6's were reported to handle higher voltages found in vintage Deluxe Reverb amps run on modern mains voltage. The current JJ 6v6S data says max 450Vp!!! Running them into a 7.2k load seems prudent and I think you're fine."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostI know that the older JJ 6v6's were reported to handle higher voltages found in vintage Deluxe Reverb amps run on modern mains voltage. The current JJ 6v6S data says max 450Vp!!! Running them into a 7.2k load seems prudent and I think you're fine.
Originally posted by daz View Postare u saying they changed them?
Originally posted by Chuck H View PostThe current JJ 6v6S data says max 450Vp!!!Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g-one View PostI guess this is why some consider them a whole other tube type, somewhere between 6V6 and "real" 5881.
I can't say about modern production tubes because they may often be some hybrid, extra durable incarnation. Old school 6V6's don't sound the least bit like 6L6's. I really like actual 6V6's. The clipping sounds throaty and splashy. Great for blues leads and pop/rock rhythm work."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostI can't say about modern production tubes because they may often be some hybrid, extra durable incarnation. Old school 6V6's don't sound the least bit like 6L6's. I really like actual 6V6's. The clipping sounds throaty and splashy. Great for blues leads and pop/rock rhythm work.
I usually forget that when people cite power tube differences they are referring to how they sound pushed hard. I'm just noting the sound when clean. But then if i notice a considerable difference clean i imagine theres even more different pushed.
From what I can tell, the reference about the JJ6V6 being somewhere between a 6V6 and real 5881 was with regard to power output.
Not meaning to stir anything up here, but when technical and engineering types compare tubes, they are comparing what is on paper, power out, curves, etc. Listening tests or what anything sounds like is not considered, as it is a matter of perception. How tubes sound is the realm of marketing, hi-fi and tube guitar amp enthusiasts.
Sorry for the sidetrack. As far as bias goes, the JJ's should be able to handle idling even hotter than traditional 6V6, so Daz you should be quite safe with those values.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I like to think I'm fairly particular and to be honest I just don't hear enough of a difference between tubes ran clean for it to matter (to me). Once you begin to compress the wave form each tube type starts to show more profound differences. Not that different tubes absolutely DON'T sound different clean. But it may be more about a particular tube under particular operating parameters, yada, yada. I think even most players that consider themselves very sensitive to nuances would be hard pressed to tell you what tube type they were using on a clean tone if you never showed them the amp. I mean, a sine wave is a sine wave!?! Once clipping starts it's often easy to tell the tube type unseen."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostI like to think I'm fairly particular and to be honest I just don't hear enough of a difference between tubes ran clean for it to matter (to me). Once you begin to compress the wave form each tube type starts to show more profound differences. Not that different tubes absolutely DON'T sound different clean. But it may be more about a particular tube under particular operating parameters, yada, yada. I think even most players that consider themselves very sensitive to nuances would be hard pressed to tell you what tube type they were using on a clean tone if you never showed them the amp. I mean, a sine wave is a sine wave!?! Once clipping starts it's often easy to tell the tube type unseen.
On a side note, i've been switching back and fourth between 6v6 and el34 the last few days, and i have been noticing the tone seemed to have changed for the worse and i couldn't figure out what happened. Turns out, and i have no idea how this happened w/o noticing it, but the impedance knob which has a set screw came loose enough to move, but when it did it stayed where it moved to w/o being loose. Don't ask me how thats possible, as i have no idea. The result was when it was looking like it was on 8 ohms it was actually on 16 and on 4 it was actually 8 ! Like with all the craziness in tweaking this amp wasn't enough, i really needed that to throw me off even more ! LOL!
In the cranked video, the first two is direct comparison between 6L6 and 6V6 in identical condition as shown. You tell me whether there is any difference.
http://music-electronics-forum.com/t35368/Last edited by Alan0354; 01-19-2014, 09:26 AM.
What people seem to always miss, and it's as important as anything else is feel ! You could record different tubes, or for that matter any number of amp and/or guitar related tweaks and if you put a gun to my head i couldn't tell you which is which. Put the guitar in MY hands and i'll tell you instantly. Feel is IMO MORE IMPORTANT than tone ! Yet it's totally ignored when amp and guitar related things are discussed. Filter caps for example....yes, they make little if any difference in sound. But the feel of a 20uf filter in my gain stages compared to 60uf which i've changed between many times is nite and day different in FEEL.
It's true i'm as far from being a tech as one can be and still build and tweak amps. But i've been playing a hell of a long time and my hearing and feel are light years ahead of my electronic theory. I can FEEL the difference between 6V6 and 6L6 clean easily. Probably hear it too, but the feel is easy to note.
6V6 are one tube you need not get hung up about with respect to voltage ratings.
Apart from their sterling service as SE and PP Audio Amps (even in mob ile gear) they were also used as Vertical Deflection Amplifiers in Black and White Televisions. Peak Positive Anode Voltage rating as a Vertical Deflection Amp is 1200V.
Cheers,
Ian
Originally posted by Gingertube View Post6V6 are one tube you need not get hung up about with respect to voltage ratings.
Cheers,
Ian
Yikes! Audiophiles are usually pretty shocked at EL84s taking +420V in old Traynors, but 6V6s are apparently super ROBUST!
