I've rebuilt an old Kay 720 for a friend. It had been modified far from the original and it sounded thin with no bottom end. I told him I'd set it up kinda like a Princeton with 6L6 outputs. The original PT had been replaced with a Hammond 278X, and it had 545V on the plates when I first turned it on. I put in five 15 volt, 5 watt zeners and a 20 volt 5 watt zener in series on the PT center tap to ground, and got the plate volts down to a more reasonable 455 volts. I had the zeners around so I used them. This is my first zener/center tap B+ voltage drop attempt.
I then set the up the pair of 6L6s as cathode bias with two 470 ohm 5 watt resistors in parallel giving me at cathode resistance of 234 ohms. I measure 31 volts at the cathode and 413 on the plates now. If my math is correct I'm drawing 132 ma current, which comes out to about 25 watts per tube.
It sounds good, but with the chassis open still open I smelled something getting hot, saw one of the zeners smoking and shut down. I figured 18 watts of dissipation across six 5 watt zeners would be 3 watts per diode. Either my math is off or I'm pushing the zeners to hard.
I found RG Keen's MOSFET B+ drop circuit (MOSFET Follies) so thought I'd try that. I happen to have a couple IRF130 MOSFETS around. I will use a 100V, 5 watt zener in conjunction with the IRF130 (max 75W dissipation). The MOSFET will be running less than 30% of max dissipation, so I don't think it will get real hot? I have just enough room for a small TO-3 heat sink in the chassis. According to the schemo on RG's site, the drain goes to ground, so I shouldn't have to insulate it from the chassis. Am I missing anything here?
