modifying the Fender Greta line out
  • modifying the Fender Greta line out
    Hey ya'll quick question. I'm trying to figure out the best way to mod this little fender head, the greta. Schematic here. I want to cut the internal speaker out when the line out is plugged in, but I'm not figuring an easy way to switch a dummy load resistor into the circuit. Would it work to have something like a 10 watt 32ohm resistor always wired in between the transformer secondary, and then short the + speaker lead to ground when a plug is inserted into the line out?
    What's the reasoning behind running the halves of V1 in parallel?
    --Jim
    He's like a new set of strings... he just needs to be stretched a bit.
      output power. parallel singled ended output section. pretty standard.
        No, putting a resistor across the secondary will still be shorted when the speaker is unplugged.
        One thing to consider is that the Line out is driven by the OT, so the sound will be a bit different with a resistive rather than speaker load.
        The simplest solution would be to connect the power resistor to a 1/4 inch jack and plug it in instead of the speaker.
        As far as V1 being paralleled, it is functioning as the power tube to drive the OT, so 2 sides paralleled gives a little more current capacity for a bit more power out.
          I ended up building a small dummy load with 2 10 watt 18ohm resistors paralleled, a 50mH inductor, and a 1000uF cap. Works nicely
            Can you post a schematic?
              pretty simple. I used a .33uH inductor for the series inductance, and a 50uH for the parallel. The series resistance is ~8ohm 20Watts, and there's a 1000uf, 50V cap parallel with the 50uH inductor.
                Probably so but it's new to me, that's why I asked.
                --Jim
