Used to know how to do tube load lines and all that, but am getting older and slower !
I subbed in a nice old USA made 12AU7 for a 12AX7 in my Bassman just for experimentation, and checked the DC voltages at the tube, found that the plate resistor now had very roughly about double the voltage across it, maybe 200 volts if I remember correctly. (B+ for that preamp tube around 300V; usual plate R 100K, and cathode R 1.5K.) This put the plate R dissipation near .3-.4 watts.
My question is this... if I start fooling around with tube subbing a 12AU7 type in other amps, is there a risk of burning out the plate R ? I wasn't comfortable with my Bassman running the plate R at .4 W with a 1/2 W resistor in there, so I put a larger W value in there just to be safe, even if I don't keep the 12AU7 in there. But if I do this on other amps, who knows what wattage rating the plate R will be ? Maybe they would cheap out on modern amps and go with smaller values.... dunno.
