Fender Dual Professional reverb help
  • Fender Dual Professional reverb help
    I just pick up a Fender Dual Professional for a good price but am not happy with the reverb.It is a tube reverb and I have swapped tubes .cable and tank without much change.Does anyone know what I can do to improve the reverb in this amp?
    TIA
    what does it sound like now, and what do you want it to sound like?
      It's just kind of dull and lifeless.Not what I think of as good Fender reverb.I would like it to sound mor full,more like a Twin Reverb.
        Have you measured the plate voltage on the reverb driver tube?
        They typically are way off for a good 6V6 reverb.
        Use a 10-15 watt 2k7 dropping resistor off the B+ node that feeds the reverb OT and lower it down to something more realistic.
        Use another filter cap, like 10uF-450v at the junction of the new resistor and the reverb OT.
        Also, those reverb tanks are kinds flat sounding too.
        Consider using a different one or look for an old, used, grey one on ebay...
        Bruce
        Mission Amps
        Denver, CO. 80022
        www.missionamps.com
        303-955-2412
          anyone else noticed how crappy the replacement reverb tanks sound?? (or even OEM in the case of the Dual Professional)...
            Thanks Bruce.I'll give your suggestions a try.
              Yes... The folks from Acutronics should be taken out and bitch slapped for selling such crappy sounding tanks nowadays.
              Bruce
              Mission Amps
              Denver, CO. 80022
              www.missionamps.com
              303-955-2412
