Hello guys
in summer 2009 I started a thread where I got some useful advice from some of you amp geeks:
http://music-electronics-forum.com/t14482/
Among other things, following Bob Martinelli's advice I replaced the 6X4 rectifier tube in my Silvertone 1482 amp with two 1N4007 diodes plus a resistor in series.
The result of the mod addressed only partially one of the original issues with this amp, i.e. low (5.9 VAC) heater voltage.
Anyway... I have been using the amp until now and it worked just fine, only a tad more raucous and crunchy (gainy?) than before.
Now, while I have the chassis on my bench again for fixing a tremolo issue, I have realized that I had installed the diodes+resistor gizmo differently from Bob's advice.
The drawing below shows the current assemblage as opposed to original Bob's setup
My main concern is if the current (wrong) installation may cause any damage to the amp in the long run, or if it is anyway less than optimal and I need to put things right.
Attached is also the 1482 schematic diagram.
TIA, Carlo
Silvertone 1482.pdf
TIA, Carlo
