I had an idea i wanted to try. When i turn my amp up from bedroom level to stage volume it gets brighter as is typical. I would like to be able to have a one knob equalizer to turn the brightness down by inserting a pot and cap like a guitar's tone control in the effects loop. I would use a no load pot, probably 1 meg or at least 500k to minimize the initial engagement and would likely use only a small amount of attenuation just to take that edge off, hence a large pot value. Thinking about this it seems to me that larger cap values may be better because they would affect a large portion of the freq range thereby not creating a peak at the knee anywhere in the highs or mids. (i believe knee would be a applicable term) Do you think that's the way to go as far as cap value or no? Or do you see issues with this idea? I don't want to use a EQ in the loop because i don't want to add more circuitry and it's already much louder than i would ever need so i'm not worried abut the fact it will not only attenuate highs but the overall volume max. I more or less want the type of high end attenuation you get with a single knob amp like an old tweed deluxe. Would it be much better to actuaklly create a tweed deluxe type circuit in a box rather than just a pot and cap? I want to attenuate the added brightness while not changing the tone to any notable degree.
What cap value for this idea?
I think your idea about less attenuation with a larger cap, rather than acute attenuation with a smaller one sound right. The cap and pot values depend on the circuit because that will dictate the impedance were using to determine the affected frequency. Not that we can know what the most effective frequency to affect is!?! This is going to be a very personal matter. So, once again, as is common in your world, it comes down to experimentation.
Another thought... Why complicate the amp with "counter measure" controls? That's too fussy for me, personally. I would probably add a bright cap to the master volume to keep the tone brighter when it's down and then re-tune some overall parameter so the amp sounds right when at volume. See what I did there!?! No extra controls."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostI think your idea about less attenuation with a larger cap, rather than acute attenuation with a smaller one sound right. The cap and pot values depend on the circuit because that will dictate the impedance were using to determine the affected frequency. Not that we can know what the most effective frequency to affect is!?! This is going to be a very personal matter. So, once again, as is common in your world, it comes down to experimentation.
Originally posted by Jazz P Bass View PostGoody.
Grab two 1/4" plugs & wire it up.
