I'm need to recap my amp and can't find affordable Polypropylene Capacitors in some of the values I need. I can find metallized Polypropylene capacitors in the right values. Will they work? Or will they sound horrible? I want to recap the amp with vitamin Q caps in the next year or two but I need something that will help the amp sound better now. Waiting and saving money isn't an option. So will metallized poly caps sound ok on an amp?
What is the difference between these caps
Originally posted by corduroyew View PostI'm need to recap my amp and can't find affordable Polypropylene Capacitors in some of the values I need. I can find metallized Polypropylene capacitors in the right values. Will they work? Or will they sound horrible? I want to recap the amp with vitamin Q caps in the next year or two but I need something that will help the amp sound better now. Waiting and saving money isn't an option. So will metallized poly caps sound ok on an amp?"Stand back, I'm holding a calculator." - chinrest
I mostly just use the orange metallized polyester ones from Rapid Electronics:
http://www.rapidonline.com/productin...moduleno=62514
Are the existing plastic film caps in your amp actually starting to go leaky? To me, "Recap" means to change out the big electrolytic filter caps, when they start to go stale after 10-20 years. The plastic film type don't ever need replacing unless they are actually breaking down and making the amp malfunction."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
i agree with Steve -- when i think of "recapping" an amp, I think of replacing electrolytic caps that are old, and any coupling caps that might prove to be causing trouble. electrolytics will wear out with age. most coupling caps are self-healing and rarely cause trouble. most of the time its not worth replacing them unless you just like to solder.
the only time that i've ever had a metallized or a film foil cap go bad was when it was subjected to mehanical trauma. in my case, it was on the crossover board in a set of very expensive HiFi speakers, where a plastic cable-tie had been used to hang a very heavy inductor on the bottom of the board. the cable tie went around the inductor, through the board, and around a PP film/foil cap. what a stupid idea. the weight of the inductor and the tension that it placed on the cap caused enough mechanical trauma to cause the cap to fail. its pretty rare to see film/foil or metallized caps fail otherwise.
id you've got a really old amp, you might run into paper in oil coupling caps that get leaky and need to be replaced, but a good film foil or metallized coupling cap should last a lifetime.
as far as selection goes, i base my selection on form factor and on price. for axial lead caps, i like the M150. for radial lead caps, i like the ODs though the Xicon caps can be found a bit cheaper. i think that just about everyone would agree that the VALUE of a coupling cap matters a lot more than its construction."Stand back, I'm holding a calculator." - chinrest
Originally posted by Steve Conner View PostI mostly just use the orange metallized polyester ones from Rapid Electronics:
Are the existing plastic film caps in your amp actually starting to go leaky? To me, "Recap" means to change out the big electrolytic filter caps, when they start to go stale after 10-20 years. The plastic film type don't ever need replacing unless they are actually breaking down and making the amp malfunction.Last edited by corduroyew; 08-29-2007, 05:23 PM.
don't forget the resistors!
Double check those carbon comp resitors, if you haven't already. If they're much more than 10% out of tolerance suspect them as contributors to you problem sounds.
Personally, I'd replace them if they were even 10% out. That's a bit fussy but I've found so many CC's that were noisy, especially plate load resistors, that I have found it easier to simply take them out even if it turns out that they weren't the problem afterall. Unless of course my customer simply must have them.....then there's always the Xicon replacements.
Marc
A 1966 ab165 bassman hmm?
It probably had the blue "molded" mallory coupling caps in it right? Those rarely go bad, and sound very nice. I would have only replaced the ones that were bad myself, and would have used polyester replacements instead of polypropylene, but each to his own. Those blue molded ones were polyester and go for high dollars online from some vendors.
Greg
Greg
