Hi ya. I have a Bugera 333xl infinium 120w head. I have been told that I can remove either the inner 2 tubes or the outer 2 tubes to halve the output. Does this alter the output impedance.? I'm going into an Engl E212VB PRO 2x12 Vertical Slanted Cabinet 8 Ohm. What should the impedance switch on the amp be set to.? 4,8 or 16 Ohm.?
Thanks in advance.
Thanks in advance.
