I'm planning to build a plexi that will essentially be a 1959 plexi bright circuit, with a switch to cascade into a 2203. The circuit will be modded to 12xxx spec and Rockstah's Mod5 modifications, following SDMs 2-in-1 layout for the switching of the stages (not accounted for in this schem).
![](http://music-electronics-forum.com/attachments/39788d1467770805-mod5.png)
I want to add another switch to add an additional 2.7k/.68u stage on the front of the 2203 from above. My inspiration is the Friedman HBE sound or that John Sykes Bad Boy Live growl. Looking at schematics, the main difference I see is with the HBE there isn't a 10k stage, and it is another 2.7k/.68u in place of the classic 10k unbypassed cathode.
![](http://music-electronics-forum.com/attachments/39789d1467770843-be100-v2-rev1.5.png)
I'm aware of the SLO style of cold clipping this stage at 39k here, too. I've seen discussions of going colder than 10k with others in a 2203 spec, but haven't seen anyone actually validate results.
I see the AFD100 AKA Caswell #4/#39 mod uses TWO of the 10k stages:
![](http://music-electronics-forum.com/attachments/39791d1467779847-39v2-1.jpg)
So, what are thoughts on how to handle this stage if I throw another stage in front of a 2203 type spec? Should I go 2.7k (or 4.7k which seems to be a common mod) w/ .68u, or leave the unbypassed 10k? Or make it colder to 39k? Any advantage to putting all three options on a rotary switch? I feel I need to leave the unbypassed 10k at least as an option for the classic 2203 sound, but interested what to do here when there is that gain stage in front of the 2203 circuit.
Also, any concerns with the stock 470k(w/470pf)/470k voltage divider here in any of the above?
