Hi, I've an easy question for you but I am not so good doing this.
This is the schematic of the footswitch of my Mesa F-50.
It's easy but I need 2 changes:
1) I need that when I change channel thel first LED will change from green to red. With the original footswitch in crunch channel the LED just turns off. (I have a double color LED)
2) I need that the contour mode (with his red LED) will show me if the Contour is on even in the clean channel. It turns off when I change to clean channel and sometimes I forget if the contour is on.. and when I pass to channel 2 it's on.. I hope you understand what I mean.. I just need to see if Contour is on even when I'm on clean channel and it this way I can choose to have the crunch channel or the contour when I come back to channel 2
Can you draw the mod in the scheme I've done? Thanks you all!
