i have a Fender Vibrochamp. about a year ago i was at the Torres Engineering site and thought id try the Bias kit for the champs. he claims you CAN adjust the bias on a cathode biased amp, simply by taking a few measurements, and swapping out this resistor. i followed the directions and replaced the 470uf 1w resistor (going to pin 8 of the power tube) with a 840uf 5w (or thereabouts... there were many that came in the kit, and this seemed like the one to use)
the problem is, i have since lost the instructions and all the rest of the resistors, so i dont know if its "right" any longer. (i have replaced the power tube with a new JJ. i also have a new Tung-Sol 6V6) its pretty clean up to about 4, then it gets dirty pretty quick. by 6 or 7 its "full on" overdrive!
SO MY QUESTION IS: what should this bias be? how do i measure? volts? resistance? measure from where to where?? im lost.
anyone?
thanx!
- jim
anyone?
thanx!
- jim
