Adjustable bias and measuring points Valve King 112
  • Adjustable bias and measuring points Valve King 112
    Hi guys,
    I'll be adding a bias pot and measuring jacks at the back panel of the amp.
    Most people added one 1Ohm cathode resistor on pin 8 of power tubes, each. I am not planing on adding balance pots for each tube (and my tubes are well matched)so my first question is if it's okay to add cathode resistor to only one tube and its measuring point respectively, for bias monitoring?
    My second question is if it is okay to add a measuring point from pin 3 to the back so I can monitor plate voltage from outside while biasing?
    This way I would have 3 banana jacks and a hole for cermet bias pot at the back. 1 jack for bias, 1 jack for ground and 1 jack for plate voltage...
    Or just a few screws and the chassis comes out for easy access.
    You may not plan to make individual adjust controls - and I myself think that would be overkill - but really, add the 1 ohm resistors to all four sockets, even if you only bring one to the panel. It will give you current reading access for troubleshooting later in life. And resistors are cheap.
    My personal choice would be pin jacks rather than banana. A pin jack takes your probe point. My concern is that you want a jack that has no chance comeone can touch it with a finger, and is not readily poked my anything conductive. That is going to be 400-500 volts, which is lethal. Or thinking about it, maybe a terminal strip behind a rectangular chassis hole, and a screw-on cover plate. Then you remove the cover plate, and can probe all four points, well five including your tube plate.
    One could have four test points brought out to one jack with a four way selector switch next to it.
    I personaly am not comfortable with plate voltage on a test point, but I am sure many guys do it. All it takes is one moron with a paper clip sticking it in ther thinking "Oh these test points only have a few millivolts..." Help, I've fallen, and I can't get up.
    As far as the amp is concerned, test points don;t exist, so add them as you like. I explained my thoughts on it, but none of the arrangements affect performance, so one post or four, go ahead.
      Thanks Enzo.
      I got vk 112 so only two power valves.
      The banana sockets I got are insulated and I have test cables for multi meter with banana jacks on other end.
      Concerning the plate voltage banana socket it would be safe from anybody poking there.
      It's just that I've never seen people doing bias mods and adding plate voktage test points and that's why I asked.
      Anyway I'll add a resistor to the second tube also when I am already inside.
      One thing I don't like is drilling but I have to do it hahaha...
      One for the MV pot, 3 for bias and 1 for boas pot...
        My take on safety:
        A friend of mine had a 3 year old son, and the kid liked to play with dady's key ring. Shiny and jingley. One day the kid wandered into the room, and said "Daddy, it hurt me." He got up to go see, and found the kid had inserted a key into a wall outlet hot side, and the sparks had burned little fingers. Who would'a thought?
        Sure, guys have put plate test points on their panels. COmmercial amp makers wouldn't do that though.
          My take on safety:
          I guess... Better safe than sorry. I'll better put a plastic plug in that socket...
          Thanks Enzo
            Thanks Enzo
            I don't like the idea of having the plate voltage on a banana socket either. It will have to withstand a peak voltage of nearly 2 x plate voltage at full output. I'd use a 1000:1 divider (1M:1k) to the socket and use the meter on the mV scale to measure volts. That would make it safe (450mV) and short circuit proof.
              Thats a great idea Dave...
              So a 1Meg to pin 3 than 1k from it to ground and then a wire to the socket from the point between the two resistors.
              1k/1.001M x 450V = 0.449 Volt
              Thanks man, should've thought about it myself...
                VK112 Bias Test Points
                Thought I'd register as a MEF member so I could chime in on this thread. I just added both a bias pot and bias test points to my VK112. I didn't find any web references to adding bias test points to the VK112 so I thought I'd document what I did.
                I drilled through the PCB trace coming off pin 8 from each of the 6L6, this was the 'iffy' part when I first considered this mod. Works great!
                I can't seem to insert a photo from my local drive...
                BTW, the bias was cold as suspected; 22ma/24ma
                Last edited by LesPaulLarry; 04-17-2019, 03:37 PM. Reason: trying to insert picture
                  Welcome LPLarry and thanks for the post.
                  When you reply, make sure you click on the "Go Advanced" button - that will bring up the tools for uploading photos.
                  I want to make sure I understand what you did. Instead of running wires to the pins of the tube sockets, you drilled through the trace and connected wires directly to the trace? I would worry that the trace could be compromised over time.
                    Sorry cant upload anything it seems... I'll try to upload the file and post a link later
                    So it works now.
                      VK100 test points /bias pot and A/AB removal (PROBLEM PLEASE HELP)
                      I follow the ultimate-guitar-valveking - Amp Mods - Electronics guide to make all this mods to my valve king
                      After that I switched on the amp and all it was ok
                      Then I switch on the stand by and I get a big flash under the C204 Capacitor
                      which could be the problem?
                      somebody can help me? Where I can find the solution?
                      I checked again all the connection but everything seems me perfect made, but obviously there is a mistake somewhere
                      Thanks again for helping
                        At the point where C204 was soldered to the PCB, the tin loosened and a created bad contact (cold solder).
                        The big flash under the C204 capacitor that appears when standby turn on is because the C204 drag current at that moment.
                        Re soldering contacts from C204 on PCB.
                        https://www.youtube.com/watch?v=VLubdi6aC3g
                        How to repair cold solder joint
                        https://learn.adafruit.com/adafruit-guide-excellent-soldering/common-problems
                        Common Soldering Problems
                        It's All Over Now
