Hello all,
I have a Peavey Butcher that has become my mod test bed. I have been trying to get the amp to have more bass response and higher gain. I had previously added a choke, bias adjust, and changed the tone stack to be more similar to a Fender silverface than a Marshall JCM 800.
Recently, in order to increase low end I have also removed the bright cap and the "treble peaking" circuit between the first and second gain stages. This also entailed removing the 470k voltage divider and replacing with a single 1M load resistor.
I'd like to replace all the load resistors between gain stages with 1M audio taper pots for individual stage gain control.
In order to further increase gain, I wanted to convert the second half of the second 12AX7A, currently being used as the cathode follower for the tone stack, into a fourth gain stage. Concurrently, I wanted to ensure the tone stack does not excessively load the third gain stage.
Looking at the circuit design of many op-amp based preamps and pedals, it occurred to me to place the tone stack in the negative feedback loop between the output transformer and the phase splitter. Essentially I want to replace the presence circuit with a more comprehensive tone stack.
Questions:
Is this phesable? If so, does anyone know of any tube amps that utilize this circuit so I can cross-reference some existing schematics?
Are there simpler ways to increase gain?
What are some other things to try to increase the bottom end?
Should I still keep some sort of fixed resistive load between each stage, or is it OK to have pots as the only load resistors?
Are there any slick mods to simulate a Clean and gain channel (preferably footswitch operated) in a single channel amp? Maybe use a relay to shunt all the stage gain pots to full load resistance?
Thanks!
Questions:
Thanks!
